Hello
Guest
it is
November 20, 2026, 07:12:59 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
G CODE TO CUT PARAMETRIC CURVES.
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: G CODE TO CUT PARAMETRIC CURVES. (Read 16088 times)
TheNigerian
14
on:
September 15, 2010, 08:46:47 AM »
Greetings.
I am looking for information about writing GCode to cut mathematical curves in wood.
For example, code to cut a sin curve.
If I can see an example, I am sure I can take it from there.
Help appreciated.
Logged
Ya-Nvr-No
992
Re: G CODE TO CUT PARAMETRIC CURVES.
Reply #1 on:
September 15, 2010, 07:32:30 PM »
make a mcode and call it up in a program
m1212.m1s
For varX = 1 To 10
varY = Sin (varX)
Code "g0 X"& varX & "Y"& varY
Next varX
Logged
TheNigerian
14
Reply #2 on:
September 17, 2010, 08:45:26 AM »
I thank you bud.
Obviously, it is not the stroll in the park I imagined it would be.
Do you have any references to custom mcode coding please. I want to do some reading.
Logged
BR549
6,965
Reply #3 on:
September 17, 2010, 03:45:59 PM »
There is also a parametric side of Gcode that you may want to look at. It has most of the math processes you may need such as sin cosin,etc
Just a thought, (;-) TP
Logged
TheNigerian
14
Reply #4 on:
September 20, 2010, 12:51:35 AM »
Hi.
I am very intersted in that too.
Can you point me in the direction of texts/sample parametric gcode please?
I just want to control my shapes very directly in mach3.
Logged
BR549
6,965
Reply #5 on:
September 20, 2010, 10:34:43 AM »
Look in the Mach Manual under Gcode parameters/variables.
Logged
TheNigerian
14
Reply #6 on:
September 20, 2010, 10:36:13 AM »
Thanks bud.
Will do and revert.
Logged
TheNigerian
14
Reply #7 on:
September 21, 2010, 05:10:53 AM »
Wow: All of chapter 10.
Guys, I thank you very much indeed.
Deep regards.
Logged
Print
Pages:
1
Go Up
« previous
next »
