Hello Guest it is October 07, 2026, 05:41:58 AM
Author Topic: A axis DRO updated with Z axis co-ordinates in path screen  (Read 16284 times)
Offline mick
  •  60 60
« on: September 13, 2010, 11:00:08 AM »
Dave,
        just noticed that the A axis dro's are being updated with Z axis co-ords on the path screen,
         the gcode prog i was running only uses x,y,z .
        MSM rel 10
        mach3 ver  43.022.
       By the way the A axis does'nt move only the dro's
        rgds Mick.
Re: A axis DRO updated with Z axis co-ordinates in path screen
« Reply #1 on: September 13, 2010, 11:19:12 AM »
Mick,
Thanks for spotting that. I've fixed it - fix will be in the next MSM release.
It was a bug in the 10x7 resolution set file. It's ok in the 12x9 resolution.
If anyone needs this fix quickly, let me know - otherwise I'll let it wait until there is enough to make a release.
« Last Edit: September 13, 2010, 11:20:52 AM by DaveCVI »
Author of the MachStdMill Extensions for Mach3
www.CalypsoVentures.com
« Reply #2 on: September 16, 2010, 10:18:37 AM »
Beta 11 is on the way to the server - it has the fix for this in it.
