Hello
Guest
it is
November 13, 2026, 12:57:34 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
MOTORS NOT WORKING PROPERLY
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: MOTORS NOT WORKING PROPERLY (Read 10104 times)
inivator
102
on:
September 10, 2010, 02:55:36 PM »
THE Y AXIS DRIVE SOMETIMES HAS MICRO-SECONDS OF STOP. THE MACHINE HAS NO BACKLASH RUNNING. THE DRIVE COMES TO A COMPLETE MS STOP, AND THEN CONTINUES.
Logged
Carnoustie, Scotland
Re: MOTORS NOT WORKING PROPERLY
Reply #1 on:
September 10, 2010, 03:06:45 PM »
Sounds like its a hardware issue. Check your wiring carefully then if that is ok the only real option is to swap around hardware from axis to axis to see if you can find the problem.
Logged
inivator
102
Reply #2 on:
September 10, 2010, 03:34:36 PM »
I'LL TRY IT ..... THANKS
Logged
Print
Pages:
1
Go Up
« previous
next »
