Hello Guest it is September 06, 2026, 10:58:30 AM
Author Topic: problem with V2.0004  (Read 16338 times)
« on: October 24, 2006, 05:12:24 PM »
Brian,
I did a clean install of V2.0004 and loaded a small part and the leadout is goofy
I reinstalled V2.000 and it is ok-- see picts
any ideas nothing else changed same xml.
chuck
Re: problem with V2.0004
« Reply #1 on: October 24, 2006, 05:46:20 PM »
Did you check that the IJ mode was not changed. I know you used the same .xml but I saw this happen once a long time ago and I never manually  changed the mode.
« Reply #2 on: October 24, 2006, 05:53:19 PM »
actually that was the first thing I checked because it burnt me one time before.
thanks Hood
« Reply #3 on: October 24, 2006, 10:35:33 PM »
Okay,
Art was doing a bit of work on Comp and may have had a bug get in on him :( That is not a good section of code... poor Art!
Please post the section of the file that is the problem.
Brian
www.newfangledsolutions.com
www.machsupport.com
« Reply #4 on: October 24, 2006, 11:10:34 PM »
Brian,
here is the whole code -all was created with NS wizards key way and cut rectangle.
thanks,
chuck
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #5 on: October 25, 2006, 08:29:42 AM »
Hi Guys:
  My abject appologies. I was working on another problem and introduced that bug to the code. Redownload, it is fixed.
Art
« Reply #6 on: October 25, 2006, 09:54:41 AM »
Art,
0005 has the same problem.
chuck
Offline ART
  •  1,703 1,703
« Reply #7 on: October 25, 2006, 10:07:27 AM »
Chuck:
  Is it .005 from yesterday, or today, I updated in a cuple hours ago with the fix. I just didnt update the version.
I ran your file here and the leadout seems fine. Can you confirm you redownloaded it or did you just check the version
and figured it was the same?
Art
« Reply #8 on: October 25, 2006, 10:42:01 AM »
Art,
todays ver works great, thanks.
while I got your attention why does my mach3mill.xml file get over ridden when I upgrade ever since ver2? it did not do this before Ver2.
chuck
