Mach Discussion => General Mach Discussion => Topic started by: chuckels on October 24, 2006, 06:12:24 PM
Brian,
I did a clean install of V2.0004 and loaded a small part and the leadout is goofy
I reinstalled V2.000 and it is ok-- see picts
any ideas nothing else changed same xml.
chuck
Did you check that the IJ mode was not changed. I know you used the same .xml but I saw this happen once a long time ago and I never manually changed the mode.
actually that was the first thing I checked because it burnt me one time before.
thanks Hood
Okay,
Art was doing a bit of work on Comp and may have had a bug get in on him :( That is not a good section of code... poor Art!
Please post the section of the file that is the problem.
Brian
Brian,
here is the whole code -all was created with NS wizards key way and cut rectangle.
thanks,
chuck
Hi Guys:
My abject appologies. I was working on another problem and introduced that bug to the code. Redownload, it is fixed.
Art
Art,
0005 has the same problem.
chuck
Chuck:
Is it .005 from yesterday, or today, I updated in a cuple hours ago with the fix. I just didnt update the version.
I ran your file here and the leadout seems fine. Can you confirm you redownloaded it or did you just check the version
and figured it was the same?
Art
Art,
todays ver works great, thanks.
while I got your attention why does my mach3mill.xml file get over ridden when I upgrade ever since ver2? it did not do this before Ver2.
chuck
