Hello Guest it is November 13, 2026, 02:52:09 PM
Author Topic: Jog Z axis when in program... (?)  (Read 10971 times)
« on: September 08, 2010, 10:57:52 AM »
Possible while the machine is running a program, to move the Z axis with a button?
I use the mach for cutting with waterjet.
Sometimes i need to move Z axis up or down manualy, while running.
Any ideas?
Thank you.
Re: Jog Z axis when in program... (?)
« Reply #1 on: September 08, 2010, 11:10:49 AM »
You can set-up THC UP and THC DOWN in Ports n' Pins and assign the inputs to buttons or hotkeys. Works well here in sim.
Russ
« Reply #2 on: September 08, 2010, 11:17:28 AM »
Thank you for the quick reply.
This will activate just an output.
My Z axis is pulse controlled by mach.
« Reply #3 on: September 08, 2010, 11:56:59 AM »
OK
I found (after long time) a topic that suits my question.
http://www.machsupport.com/forum/index.php/topic,2656.0.html
