Hello Guest it is November 13, 2026, 01:02:31 PM
Author Topic: Mach 3 doing wierd things  (Read 78539 times)
Re: Mach 3 doing wierd things
« Reply #20 on: September 07, 2010, 03:45:38 PM »
I notice you have pin 16 used for spindle step, spindle Dir and also OutPut 1, doesnt seem like that would be correct to me. Likely not your problem but.....
« Reply #21 on: September 07, 2010, 03:58:24 PM »
I Think that was for the previous BOB that I was using. I am manually starting the spindle, I can change this if you think this is a problem. Although it has been set this way for almost a year.
« Reply #22 on: September 07, 2010, 04:01:37 PM »
Mach is looking at one pin for three different things, whether it would cause issue I cant say for sure but definitely best not to have it that way.
Dont see anything else unusual about your xml so far.
« Reply #23 on: September 07, 2010, 04:04:03 PM »
I see you have the macropump enabled, what code do you have in it?
« Reply #24 on: September 07, 2010, 04:11:08 PM »
Here you go
« Reply #25 on: September 07, 2010, 04:14:13 PM »
Looks innocent enough, what exactly is it for?
« Reply #26 on: September 07, 2010, 04:20:15 PM »
I used to have a remote button that was used for the ATZ feature. I since turned off the brain and I use the button onscreen. I was having trouble were the ATZ would not get the true zero. Maybe I should eliminate this, but I don't see how it can change the X,Y origin.
« Reply #27 on: September 07, 2010, 04:23:23 PM »
Not likely to be the problem but again if you dont use it no point in it taking up resources. Presume your m615 macro doesnt do anything to X or Y axis?
« Reply #28 on: September 07, 2010, 04:25:56 PM »
That is the macro for the ATZ remote button, I don't see anything to do with X,Y axis.
« Reply #29 on: September 07, 2010, 04:28:44 PM »
Ok so same code as you posted before so no problems with it.
Looks like  a reinstall would be the quickest way. Instead of deleting the Mach3 folder just rename it, that way if you need anything from it it will all be there but set up a new xml in the fresh install as it could be something in the xml causing the issues and you dont want to copy it back.
