Hello Guest it is October 25, 2026, 06:44:29 AM
Author Topic: ref all home setup  (Read 24662 times)
Re: ref all home setup
« Reply #10 on: September 04, 2010, 10:43:30 AM »
Thanks all. Have got it working :) On with the next callenge.....will no doubt be back to pick your brains
« Reply #11 on: September 04, 2010, 10:46:32 AM »
For the benefit of others, what was the problem?
Bill (the Cat) Shubert
« Reply #12 on: September 04, 2010, 11:06:46 AM »
I need some help on getting a dxf file to load into lazycam.  I make my dwgs in autocad, save as dxf and try to open in lazycam, but the dxf file does not show up....Can anyone help?
« Reply #13 on: September 04, 2010, 12:16:22 PM »
Just for the future, you should try to post LazyCam questions in the LazyCam area of the forum and start a new thread.
As for the DXF issue, try saving it as an 11/12 vesrion of a DXF. Also, I personally used to use AutoCad, but had similar problems exporting. Then I switched to ProgreCad (free autoCAD clone) and I haven't had issues after that.
« Reply #14 on: September 04, 2010, 01:06:03 PM »
yes, what cured the problem, and what was it eventually.
« Reply #15 on: June 07, 2014, 11:17:37 AM »
I am having the same problem. The led's light up in the diagnostic page when I press any 1 of the 3 home switches, but when I ref all, the axis motor does not stop. I crossed checked the port and pin configuration between the c25 bob and the home settings and they are match. I am using an ESS board between the machine and computer. Everything else works fine including all axis movements. I have also tried my laptop, but the results are the same. There must be a parameter setting that I am missing? Stumped on this one!
