Hello Guest it is November 13, 2026, 11:29:44 AM
Author Topic: OEM LED codes for Output7 - Output20  (Read 16840 times)
« on: September 01, 2010, 10:31:29 AM »
Are there OEM LED codes for the higher numbered Outputs?  Can't seem to find them anywhere?
Mainly Output20, 19, 18 and 17
JH
Re: OEM LED codes for Output7 - Output20
« Reply #1 on: September 01, 2010, 12:14:01 PM »
Not as far as I know. You could use a Brain to set a user LED if you wished.
« Reply #2 on: September 01, 2010, 02:23:27 PM »
Bummer.... and thanks hood
« Reply #3 on: September 04, 2010, 08:40:48 AM »
Hey JH,
     Here is a Solution for your issue, the missing I and O LEDs in the upper ranges has been an issue for a long time.
http://www.machsupport.com/forum/index.php/topic,10861.0.html
That is a Plugin that Maps ALL the missing Inputs and Outputs to LEDs, it is the "Standard OEM" Mach Mill screen, but I Modified the Diagnostic screen with the Missing LEDs.
It does this, and uses these resources:
Inputs:
1).   OEMTrigger's 1-15
Outputs:
1).   OUTPUT's 7-20
2).   Charge Pump, Charge Pump2, and Current Hi/Low
ULED's Used for Input Signals are:
1).    1301-15 is used for OEM trigs 1-15
ULED's Used for Output Signals are:
1).    1316-32 is used for Outputs 7-15,Charge Pump,
   Charge Pump2 and Current Hi/Low
Also, if your doing alot of R & D, or customizing, look into Mach MAD, it was built for just that........
scott
« Reply #4 on: September 04, 2010, 08:48:43 AM »
Thanks Scott !
I mapped them to user LEDs and updated my macroPump to read to output states and update the LEDs.  But I like this better!
What is Mach MAD ?
JH
