Hello Guest it is October 21, 2026, 12:19:20 PM
Author Topic: Soft Limits  (Read 20623 times)
Soft Limits
« on: August 28, 2010, 04:28:57 PM »
Very Newbie!  Up and running but having trouble setting soft limits!  I have set them X=48 inches  Y = 24 inches and Z is set from the top at 5 inches!  When I try to use the soft limits I get an error saying I'm not withit in limits!  That is the working size of my table!  Can anyone help this old man/
Re: Soft Limits
« Reply #1 on: August 28, 2010, 04:39:11 PM »
Do you have limit switches and which end of the travel are they?
X and Y Min and Z Max should be Zero
X and Y Max and Z Min should be the travel of your axis with the Z being a negative number.
If your home switches are at the positive ends of the travel you will need to set up a Home Off value equal to the distance of the axis.
Re: Soft Limits
« Reply #2 on: August 28, 2010, 04:50:26 PM »
Hood, I have them as you stated!   48-0  24-0   Z = 0  -5
Re: Soft Limits
« Reply #3 on: August 28, 2010, 04:52:50 PM »
In my post above I meant to say home switches, so with that in mind do you have home switches and which ends of each axis are they?
Re: Soft Limits
« Reply #4 on: August 28, 2010, 04:53:06 PM »
Limits , yes    x &y - = home
Re: Soft Limits
« Reply #5 on: August 28, 2010, 04:54:32 PM »
and Z?
Re: Soft Limits
« Reply #6 on: August 28, 2010, 04:54:58 PM »
Limit switches are my home switches!
Re: Soft Limits
« Reply #7 on: August 28, 2010, 04:56:02 PM »
No switches on Z!
Re: Soft Limits
« Reply #8 on: August 28, 2010, 04:58:14 PM »
OK move Z fully up and then Ref All, you should then be able to switch on Soft Limits after you have done that.
Re: Soft Limits
« Reply #9 on: August 28, 2010, 06:02:44 PM »
Still Not working!  I have to leave but would appreciate any thoughts on this matter!  I will check the postings tomorrow!
Thanks Hood.
