Hello
Guest
it is
November 22, 2026, 09:02:57 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
setting machine coordinates to zero??
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: setting machine coordinates to zero?? (Read 12279 times)
dougie329
48
on:
October 22, 2006, 07:59:24 PM »
ok here is my problem, I load mach 3 up with a program and then turn my cnc controller on. Both current position and machine coordinates are all zero, i then machine a part. If i move the axis to set the datum for another part and zero x & y then the machine coordinates are no longer zero and when it is done it returns to machine zeros which is a pain?? how can i zero the machine coordinates without rebooting everything? cheers
Logged
sshneider
401
Re: setting machine coordinates to zero??
Reply #1 on:
October 23, 2006, 05:58:08 AM »
You Can't reset machine coordinates as you describe. You can however, use work/fixture offsets to rezero and deal with the problem you are having.
Check out the Coordinates/Homing video tutorial
HTH
Sid
Logged
Print
Pages:
1
Go Up
« previous
next »
