Hello Guest it is October 17, 2026, 06:45:51 PM
Author Topic: setting machine coordinates to zero??  (Read 12009 times)
« on: October 22, 2006, 07:59:24 PM »
ok here is my problem, I load mach 3 up with a program and then turn my cnc controller on. Both current position and machine coordinates are all zero, i then machine a part. If i move the axis to set the datum for another part and zero x & y then the machine coordinates are no longer zero and when it is done it returns to machine zeros which is a pain?? how can i zero the machine coordinates without rebooting everything? cheers :)
Re: setting machine coordinates to zero??
« Reply #1 on: October 23, 2006, 05:58:08 AM »
You Can't reset machine coordinates as you describe.  You can however, use work/fixture offsets to rezero and deal with the problem you are having.
Check out the Coordinates/Homing video tutorial
HTH
Sid
