Hello
Guest
it is
November 13, 2026, 10:13:00 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
VB and the development of wizards
macro when starting mach or after reset
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: macro when starting mach or after reset (Read 8989 times)
tantan
130
on:
August 16, 2010, 06:13:24 AM »
hi all.
i want to run a macro after mach has been started. how should that be done,
thanks for your answer.
antoine
the neterlands
BR549
6,965
Re: macro when starting mach or after reset
Reply #1 on:
August 16, 2010, 09:32:05 AM »
Reference the macro as a Mcode in the initializaton section in Gen Config.
tantan
130
Reply #2 on:
August 16, 2010, 09:44:48 AM »
hi,
thanks for your reply, but can you give me an example: my initialisation string now only has "G80" in it. the name of the macro is test.m1s, should i make my initialisation string "G80 test.m1s"
thanks,
antoine
BR549
6,965
Reply #3 on:
August 16, 2010, 10:12:11 AM »
You need to rename your Macro AS say M300 and place it in the macro directory. Then the string would read "G80 M300"
tantan
130
Reply #4 on:
August 16, 2010, 11:15:23 AM »
hi
Thanks, Works Perfect!!!!
Antoine
Print
Pages:
1
Go Up
« previous
next »
