Hello Guest it is November 13, 2026, 10:13:02 PM
Author Topic: macro when starting mach or after reset  (Read 8990 times)
Offline tantan
  •  130 130
« on: August 16, 2010, 06:13:24 AM »
hi all.
i want to run a macro after mach has been started. how should that be done,
thanks for your answer.
antoine
the neterlands
Re: macro when starting mach or after reset
« Reply #1 on: August 16, 2010, 09:32:05 AM »
Reference the macro as a Mcode in the initializaton section in Gen Config.
Offline tantan
  •  130 130
« Reply #2 on: August 16, 2010, 09:44:48 AM »
hi,
thanks for your reply, but can you give me an example: my initialisation string now only has "G80" in it.  the name of the macro is test.m1s, should i make my initialisation string "G80 test.m1s"
thanks,
antoine
« Reply #3 on: August 16, 2010, 10:12:11 AM »
You need to rename your Macro AS say M300 and place it in the macro directory. Then the string would read "G80 M300"
Offline tantan
  •  130 130
« Reply #4 on: August 16, 2010, 11:15:23 AM »
hi
Thanks, Works Perfect!!!!  :)
Antoine
