Hello Guest it is November 07, 2026, 11:48:58 AM
Author Topic: Our 2440 x 1220mm CnC Router Builds  (Read 48199 times)
  •  9,375 9,375
Re: Our 2440 x 1220mm CnC Router Builds
« Reply #10 on: August 21, 2010, 03:58:19 AM »
Thanks for the pictures Tony. If this works as good as it looks (and I am certain it will) you are going to have a machine to be really proud of. It looks so professional  :D
« Reply #11 on: September 13, 2010, 05:30:11 AM »
Hi All,
Latest update photos, getting closer  ;)
Tony.
« Reply #12 on: September 13, 2010, 10:16:07 AM »
Looks great !  Can't wait to see the videos !
JH
« Reply #13 on: September 13, 2010, 10:48:46 AM »
Excellent work, well done!
« Reply #14 on: September 13, 2010, 02:31:08 PM »
That looks really nice!
« Reply #15 on: September 13, 2010, 05:52:24 PM »
Beautiful work Guys, very impressive job
  •  9,375 9,375
« Reply #16 on: September 16, 2010, 02:23:41 AM »
Hi Guys,
Your workmanship is truly remarkable.
One thing which you haven't mentioned here, which I think is absolutely amazing, is that you cut down one side of all the (black painted) 2 1/2" angle, ground the top surface flat and then ground the 'V' rails all with a hand held Bosh angle grinder. OK, I know you used a homemade jig but it is still a monumental task to complete.
You Guys have my total admiration.
Can't wait to see your pictures of the Roadrunner.  ;D
« Reply #17 on: September 16, 2010, 04:09:51 AM »
Tweakie,
Your attention to detail is awesome  ;) the rail grinding would be one of those tasks most would put off and off. Once you get into it and set yourself up too do it and with the right mind set it really is not that bad. Time taken to get it right is time well spent.  ;D
Roadrunner here we come  ;)
Tony.
« Last Edit: September 16, 2010, 04:13:24 AM by AuS MaDDoG »
« Reply #18 on: September 19, 2010, 04:26:34 AM »
Some more progress today!!
Racks all mounted as well as all motors fitted. Only the electrics/electronics to be done now and all done and dusted. !!  :)
Tony
« Reply #19 on: September 19, 2010, 01:28:12 PM »
Very impressive guys.. 8) 8)
Can you tell us when to official start date was, say, when you received the materials?
Just so I can feel worse at my poor progress on my little table top CNC. :-[ :'(
