Hello Guest it is October 25, 2026, 05:56:07 AM
Author Topic: Visual mill 6.0  (Read 10688 times)
Visual mill 6.0
« on: August 14, 2010, 02:24:00 PM »
Anyone using Visual mill
 I have a few question's
 First how is the depth per pass set the cut parameters are different in roughing and finishing, second there are no feed and speed's set up for the M M tooling is there a tool libray available that has a basic feed and speed setting.
Thanks for any help
Dennis
Re: Visual mill 6.0
« Reply #1 on: August 18, 2010, 05:00:05 PM »
I use rhinocam (same as visualmill).
What type of toolpath are you trying to generate?
Ken
Re: Visual mill 6.0
« Reply #2 on: August 19, 2010, 12:14:41 PM »
Ken
Thanks for the reply i am using a 3 axis routine it programs but i can't seam to change the depth of cut i changed the number of passes and then the depth of cut and the program seams to default to a setting from where i don't know what happens is looking through the code lets say i set the depth of cut to 3.5 MM as this is what i use to design my partsthe tool path generated shows a tool path of different depth's from 1.7 and then stacks them on meaning each path is 1.7 greater i would think the tool path should be like this first depth of cut 3.5 mm and then the next to 7 mm and so on until it cuts to the bottom am i incorrect in my thinking?
Dennis
