Hello Guest it is October 30, 2026, 11:21:31 AM
Author Topic: Mach 3 Charge pump circuit layout, problem  (Read 15762 times)
« on: August 12, 2010, 09:02:42 AM »
Hi guys,
my name is Phil and I'm working on a PCB for the mach3 charge pump circuit following the circuit by Mariss Freimanis in the support download area.
I attached a picture of my layout for the circuit no. 2. It only switches my relays properly, when the voltage connected to +5V DC is lowered to about 4V DC.
The only modification I made is a IRF1404 mosfet. IC pin connections like in the datasheet of the HEF4538.
I could install a +4V voltage regulator, but this does not solve the basic problem with the circuit. I would appreciate any help or advice very much.
Thanks in advance.
Phil
  •  9,375 9,375
Re: Mach 3 Charge pump circuit layout, problem
« Reply #1 on: August 12, 2010, 11:51:57 AM »
Phil,
Dont know if this would make any difference but the capacitor in the circuit diagram is 0.01uf your pcb shows 0.1uf.
« Reply #2 on: August 12, 2010, 11:56:56 AM »
Hi Tweaky,
thanks for your reply. It would make a difference, but the capacitor in the circuit is 0.01µF. Just a typo in the PCB layout.
Phil
