Hello
Guest
it is
November 11, 2026, 08:34:33 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Motor problem
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Motor problem (Read 13242 times)
hharley
7
Motor problem
on:
August 02, 2010, 01:43:40 PM »
I had Mach 3 installed and leaning it. I could move the motors at will and do the examples . I had to reload the Mach 3 and sence then having motor control problem. No matter what arrow key i chose . It moves the X to the left only . I have checked Pin settings and they are correst. Im useing wondows XP . I have reloaded the Mach3 program and LPT driver 3 times same results
Logged
Carnoustie, Scotland
Re: Motor problem
Reply #1 on:
August 02, 2010, 01:51:40 PM »
Check to make sure you have the Dir port set correctly for that axis, if that is not the problem then it sounds like you have a loose Dir wire.
Logged
hharley
7
Re: Motor problem
Reply #2 on:
August 02, 2010, 07:22:36 PM »
I made some changes I turned on not only XY&Z but turn on AB&C and the motors started working right . I still have to have estop turned on or i cant reset ,even with machine hooked up and on, But at least the axes are all working
Logged
Re: Motor problem
Reply #3 on:
August 03, 2010, 01:14:13 AM »
Can you attach your xml please.
Logged
hharley
7
Re: Motor problem
Reply #4 on:
August 03, 2010, 03:58:35 PM »
I have solved the problem contacted Zenbot for the pin codes They had a Mach 3 configuration file . I loaded it in Mach 3 file and all working well TY
Logged
Re: Motor problem
Reply #5 on:
August 03, 2010, 04:33:26 PM »
Good to hear
Logged
Print
Pages:
1
Go Up
« previous
next »
