Hello Guest it is September 28, 2026, 08:12:20 PM
Author Topic: "No Driver Sensed"  (Read 21776 times)
"No Driver Sensed"
« on: July 18, 2010, 12:48:44 AM »
I Updated from version 2 to the current lock down. I got the "No driver sensed installed. Run driver test"  I was logged in as admin and I checked the box for driver install.
 I am running xp sp3 on a intel quad core desktop. I was not having any issue until I updated. Is there a way to manually install the driver?
 patrick
Re: "No Driver Sensed"
« Reply #1 on: July 18, 2010, 02:19:29 AM »
Have you run the driver test as it suggested? that should install the driver.
« Reply #2 on: July 18, 2010, 02:39:49 AM »
Driver test gives me the same notice I get during install. No driver sensed....
 Thanks for weekend response
 patrick
« Reply #3 on: July 18, 2010, 02:42:49 AM »
Weekend, whats that ? ;D
Try installing Mach over the top of itself again.
« Reply #4 on: July 18, 2010, 02:50:42 AM »
 365 day work week is standard for me too  ;)
 I repeated the install three times now, ran the test each time as well. same results.
 patrick
« Reply #5 on: July 18, 2010, 03:36:44 AM »
Ok, two things I would try, first is redownload Mach just in case you got a corrupt install, the other is go to device manager and see if there is a driver there, (Called Pulsing Engine if I recall),  if there is delete it and  then install Mach again.
 I am presuming that it is a 32bit windows version you are running as you said you had previously had it running fine, but thought I would just mention it just in case you have just upgraded the computer as the Mach driver will not work with 64 bit operating systems.
« Reply #6 on: July 18, 2010, 04:02:02 AM »
No pulsing driver in list. And the fresh copy gives the same result.    Windows is 32bit
 patrick
« Reply #7 on: July 18, 2010, 05:46:54 AM »
Thats  a strange one, what about reinstalling the older version you had to see if that works.
« Reply #8 on: July 18, 2010, 01:53:37 PM »
I appreciate the the assistance thank you.
 I am not sure I can find the older version, but I will look. Is there an archive of older lockdowns?
 patrick
« Reply #9 on: July 18, 2010, 01:57:53 PM »
Yes, go to the downloads page and scroll down to legacy versions. In the text there you will see a link to the ftp site and most older versions are on there.
