Hello
Guest
it is
November 13, 2026, 02:15:58 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
New Plasma Function In Mach TOOL BOX
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: New Plasma Function In Mach TOOL BOX (Read 9001 times)
BR549
6,965
on:
July 16, 2010, 08:00:51 PM »
I have just downloaded a new plasma function for those with a CanCNC DTHC. It is an auto preset function to be able to load the preset tip voltage from Gcode. This way you will not forget to preset the required tip voltage setting(;-)
YOu simply insert the macro with a P# value equal to your preset voltage and Mach will auto update the value AND notify the DTHC on file load.
Helps make plasma So easy a caveman can do it.
BR549
6,965
Re: New Plasma Function In Mach TOOL BOX
Reply #1 on:
July 22, 2010, 10:02:04 PM »
Just an update , we have the Scam post working to insert the DTHC update values into the Gcode so that MACH can update the DTHC on the fly.
No more forgetting to change the voltage settings for each cut. IT IS IN the gcode now(;-)
Print
Pages:
1
Go Up
« previous
next »
