Hello Guest it is November 13, 2026, 02:15:59 PM
Author Topic: New Plasma Function In Mach TOOL BOX  (Read 9002 times)
« on: July 16, 2010, 08:00:51 PM »
I have just downloaded a new plasma function for those with a CanCNC DTHC. It is an auto preset function to be able to load the preset tip voltage from Gcode. This way you will not forget to preset the required tip voltage setting(;-)
YOu simply insert the macro with a P# value equal to your preset voltage and Mach will auto update the value AND notify the DTHC on file load.
Helps make plasma So easy a caveman can do it.
Re: New Plasma Function In Mach TOOL BOX
« Reply #1 on: July 22, 2010, 10:02:04 PM »
Just an update , we have the Scam post working to insert the DTHC update values into the Gcode so that MACH can update the DTHC on the fly.
No more forgetting to change the voltage settings for each cut. IT IS IN the gcode now(;-)
