Hello
Guest
it is
November 13, 2026, 03:44:58 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
pause button
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: pause button (Read 17051 times)
manmeran
241
pause button
on:
July 13, 2010, 03:56:18 AM »
i have small problem
in feedrate about 1500~2000 mm/Min ,When I press the pause button ,malfunctioning and should do it again.
In other words ,i must press twice.
Where is the problem ?
my version is R3.042.020
Amir
**Even a clock that does not work is right twice a day**
Carnoustie, Scotland
Re: pause button
Reply #1 on:
July 13, 2010, 04:41:31 PM »
There have been times in the past that a double press was needed but I have not heard of any recent revisions with that issue.
Do you definitely have to press twice or could it just be it is taking a bit longer to feedhold due to the higher feedrate and you pressing twice makes it seem its needing the double press?
BR549
6,965
Re: pause button
Reply #2 on:
July 13, 2010, 08:23:54 PM »
Amir you may have to drop your look ahead down to 1 to get a faster pause.
manmeran
241
Re: pause button
Reply #3 on:
July 14, 2010, 02:05:03 AM »
yes Hood. i need press twice in high feedrate, i dont have problem in low feedrate.
hi Terry
is it possible explain about "Look Ahead" ?
Amir
Re: pause button
Reply #4 on:
July 14, 2010, 02:33:50 AM »
Look ahead is on General Config page, set it to 2 or so and see if it helps.
manmeran
241
Re: pause button
Reply #5 on:
July 14, 2010, 03:00:30 AM »
i know position for look ahead. but i dont know What does it do?
Re: pause button
Reply #6 on:
July 14, 2010, 03:41:42 AM »
Exactly as it says, it looks ahead in the code and takes it into account for planning.
I doubt that it will help for you though if you are certain that you have to press twice to get the feedhold to work.
manmeran
241
Re: pause button
Reply #7 on:
July 14, 2010, 01:34:50 PM »
i dont understand your mean.
Amir
Re: pause button
Reply #8 on:
July 14, 2010, 01:46:37 PM »
The manual has a short explanation.
BR549
6,965
Re: pause button
Reply #9 on:
July 14, 2010, 06:39:43 PM »
The look ahead also stacks the ouput buffer based partly on the look ahead size. The more look ahead the larger the buffer load to a point. That is why a large look ahead may take longer to respond to a feedhold. Where as a short look ahead responds faster.
Print
Pages:
1
Go Up
« previous
next »
