Hello Guest it is October 30, 2026, 11:52:08 AM
Author Topic: RS485/232 for axis  (Read 10573 times)
RS485/232 for axis
« on: October 18, 2006, 12:33:38 AM »
Hi All,
I am new in the Mach series CNC controlling.
I would like to use my AMC servo controllers for the axes.
It could be controlled via RS485 or RS 232 interface.
Can I use this type of communication? Or can I use the newer CAN BUS?
Regards István
Re: RS485/232 for axis
« Reply #1 on: October 21, 2006, 03:48:34 PM »
 would need to write a plug In to run the servo's like that. there is a problem with doing that because you can't move the data that you need to for 3d toolpaths... you are better of to use step and direction
BTW if you would like to do a plug in you will need VC++ 2003
www.newfangledsolutions.com
www.machsupport.com
