Hello Guest it is November 07, 2026, 10:19:04 PM
Author Topic: Is Ridgid Tap possable with Galil?  (Read 10891 times)
« on: July 08, 2010, 10:05:00 AM »
I would like to know if it is possible for rigid tap using a galil dmc card ?
Adam
Offline smurph
  •  1,575 1,575
Re: Is Ridgid Tap possable with Galil?
« Reply #1 on: July 30, 2010, 01:19:02 AM »
I put the code in there to do it, but it is NOT tested.  Try it at your own risk.  Maybe with something soft to start with.  :)
Steve
« Reply #2 on: July 30, 2010, 04:49:38 AM »
I like to rigid tap AIR.
It is very forgiving to tooling.
 ;D ;D ;D
Offline smurph
  •  1,575 1,575
« Reply #3 on: July 30, 2010, 07:38:04 PM »
Oh, the rigid tapping has to work with a spindle that has an encoder.  Do not attempt with just a VFD spindle.  Shards of carbon steel will be flying.  The spindle is electronically geared to the Z movement, so the setup needs to be tight.  But I would think that of any rigid tapping environment.
