Hello Guest it is November 14, 2026, 04:18:42 PM
Author Topic: stepper signals from breakout board  (Read 13849 times)
« on: July 07, 2010, 02:39:10 AM »
I have downloaded the demo version of Mach3. I have set up the address etc. I have leds on the outputs of the breakout board.
I can toggle these individually by playing with the active logic level and they work ok.
when I go into the diagnostic mode and use the jog command the dro changes as one would expect but the
signals to the stepper motors never change.
What going wrong?
thanks
  •  9,377 9,377
Re: stepper signals from breakout board
« Reply #1 on: July 07, 2010, 04:02:06 AM »
John,
Have you set the Motor Outputs in the Ports & Pins section ?.
btw. Welcome to the forum.
« Reply #2 on: July 07, 2010, 06:07:34 AM »
In the motor output i have
         motor   enable   step dir  s port  d port
        x          yes        2     3     1        1
       y          yes         4     5     1       1
        z          yes        6      7    1       1
i hope this is ok
john f
  •  9,377 9,377
« Reply #3 on: July 07, 2010, 07:28:33 AM »
Looks good John - that's exactly the same configuration as I am using.
You say you have the port address set correctly (0x378) I am wondering if your breakout board requires an 'enable' signal. What type are you using ?
« Reply #4 on: July 07, 2010, 10:05:43 AM »
details of the breakout board can be found at:
http://www.nbglin.com/CNC25.htm
john
  •  9,377 9,377
« Reply #5 on: July 07, 2010, 10:30:18 AM »
Sorry to keep asking all these questions but what stepper driver board are you using ?.
Looking at the bob instructions as long as you have the JN1 &JN2 connected and 5Volt power applied you should be getting an output.
