Hello Guest it is November 09, 2026, 03:37:25 PM
Author Topic: Mod I/o Question  (Read 43811 times)
Mod I/o Question
« on: October 16, 2006, 05:57:04 PM »
I was wondering about a mod I/O.
1. Can I simply hook a mod I/O straight to a printer port?
2. With a mod I/O do you have to have a rack and, or a power supply like a PLC.
3. Do you use software to config. a mod I/O or can this be done in Mach like a breakout board?
Re: Mod I/o Question
« Reply #1 on: October 16, 2006, 10:18:17 PM »
Answers to the question are below.
1. The ModIO connects to the PC via the serial port, NOT the printer port.
2. It all depends on how you plan to use the ModIO. It can be powered from a 9V-24V plugpack or via a PLC style power supply.
3. Mach 3 has a config screen  accessed from the Modbus Dialog page. Standard configuration is similar to setting up the parallel port pins. More complex tasks may require some script programming.
Also John Prentice is currently writing a "Plug-In" for Mach3 that will make the configuration even easier.
What type of things are you wanting to do with a ModIO?
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
email: peter at homanndesigns.com
« Reply #2 on: October 16, 2006, 10:45:05 PM »
I'm going to use my for front panel stuff.
Feedrate Override, Spindle Override, MPG, buttons ....
« Reply #3 on: October 16, 2006, 11:32:02 PM »
Hi Shawn,
Ok, the best way to power the ModIO is probably from a DC power pack, 9V -12V dc. The feedrates can be via potentiometers connected to the analog inputs. MPG ans other buttons/switches via the discrete inputs. If you have more than a few switches, it may be better to use the ModIO switch matrix module.
The customisation section of the Mach support Wiki has a few good examples on doingthis.
Cheers,
Peter.
Homann Designs
« Reply #4 on: October 17, 2006, 07:06:54 AM »
Thanks Guys,
    Shawn your a man after my own heart. I was also thinking of panel controls, especially analog.
