Hello Guest it is October 22, 2026, 02:43:50 PM
Author Topic: Mach 3 & C10 breakout spindle control?  (Read 12556 times)
« on: June 22, 2010, 02:53:48 AM »
Hello I'm new to this and need some training wheel help please!
I'm using M3 with a C10 breakout and id like to know how i could control the speed of my spindle, the only info i have on the spindle speed controller is  on the link below which has a diagram (and its in Japanese). Will the C10 do a variable Voltage/Current?  into the VS,VC or CC inputs?. Also how come i cant ramp my spindle speed up past 8000rpm (not that it matters at the moment)
I can turn the spindle on and off but i have no speed controll, if any one could help that would be great and much appreciated.
http://www.lingnangroup.com/ProductInfo.aspx?ProductID=229&LevelCode=00101001
D
« Last Edit: June 22, 2010, 02:59:54 AM by Darian »
  •  9,374 9,374
Re: Mach 3 & C10 breakout spindle control?
« Reply #1 on: June 22, 2010, 03:05:48 AM »
Hi D,
Unfortunately the C10 does not have the on board variable speed control (it's the model C11 that has this). However this does not stop you varying the spindle speed using a seperate PWM / 0 - 10 Volt board for controllingl your VFD.
« Reply #2 on: June 22, 2010, 03:28:38 AM »
Hi Thanks
Will look into it
D
