Hello
Guest
it is
October 25, 2026, 02:14:57 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
How to unlink Rapid Rate from Feed Rate Override
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: How to unlink Rapid Rate from Feed Rate Override (Read 19479 times)
kree8tiv
16
on:
October 14, 2006, 08:05:25 PM »
Hello,
Is there a way I can get my rapid rate to always run at top speed, even if the feed rate over ride is not at 100%? I am using 1.90.073.
Also, on my SET file, the SHIFT + Jog does not go at 100%. Any suggestions.
Cheers,
sshneider
401
Re: How to unlink Rapid Rate from Feed Rate Override
Reply #1 on:
October 14, 2006, 11:06:43 PM »
G1 commands are controlled by Feed Rates & FROs. Rapid rate (G0) should not be affected by FRO. Hit your Tab key and check your slow jog rate. This is the rate your machine will jog unless you press the shift key. If it's too slow, change the value. HTH
Sid
kree8tiv
16
Reply #2 on:
October 15, 2006, 01:32:57 PM »
No, it is definately in G0 moves during a file. For some reason they are going slow. Does the slow jog speed also override G0's?
sshneider
401
Reply #3 on:
October 15, 2006, 02:41:38 PM »
Weird, G0 should run @ full speed (i.e. whatever you have set on your motr tuning settings).
Can you get your motors to turn faster by using a G01 command with say,an F150 preceeding it to make it overide to 150% of normal speed?
First I would say if you are not runing the 1.8 ver then take the leap and do the upgrade to the latest ver (I think it is RC2.0G). Then, let us know what your motor tuning settings are- something is fishy.
Sid
kree8tiv
16
Reply #4 on:
October 15, 2006, 07:43:53 PM »
Sid,
The rapid speed seems to change with the Feed Rate over ride. I am using version 1.90.073. I have been running the over ride at about 50%-75% to compensate for acceleration and CV issues in 3D files. This helps the file, but screws up the rapid moves.
We tried the latest version, but that introduced a whole other range of problems.
Thank you for your input though.
kree8tiv
16
Reply #5 on:
October 15, 2006, 07:46:07 PM »
One other thing I should mention is that I am using a custom SET file. However, the issue does present itself when the 1024.SET file is used as well.
Brian Barker
3,860
Reply #6 on:
October 21, 2006, 03:37:26 PM »
There is not a way at this time
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
ger21
6,295
Reply #7 on:
October 21, 2006, 05:19:54 PM »
In config>State, either check or uncheck "no FRO on queue". This might cause a delay when pausing, though.
sshneider
401
Reply #8 on:
October 21, 2006, 08:32:48 PM »
Brian,
Are you confirming that FRO does in fact effect a G0 command?
Sid
Brian Barker
3,860
Reply #9 on:
October 24, 2006, 10:09:43 PM »
The FRO under 100% will slow down the rate that the Rapid is done at
we are talking about adding a rapid override that will not change the feed... this should help with the problem that he is having.
Brian
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
