Hello Guest it is September 22, 2026, 04:25:41 PM
Author Topic: Go to Zero Function  (Read 9061 times)
Go to Zero Function
« on: June 11, 2010, 11:55:10 AM »
My router (a popular model) is made from MDF and the XY is not easy to square up, so I use a formula [y=y-(x*.007)] in my setup, and this works well for me (I know it should be squared up mechanically, but for now it is what it is).
However, with the formula active, if I use the "Go to Zero" button on the main screen, the X axis always returns to a negative value, but the X DRO resets to zero (the Y axis is OK).   I can work around this with a new button, but is another solution possible?
John Champlain
Re: Go to Zero Function
« Reply #1 on: June 11, 2010, 03:28:57 PM »
Sorry, it is the Y axis that changes - not X.
John Champlain
