Hello Guest it is November 22, 2026, 07:15:57 AM
Author Topic: Homing slave axis  (Read 10565 times)
Homing slave axis
« on: June 07, 2010, 08:07:27 PM »
I have a R&P driven with 2 steppers one on each end .
What is the best way to home both steppers to correct any misalignment at homing?
Offline Greolt
  •  956 956
Re: Homing slave axis
« Reply #1 on: June 07, 2010, 08:43:25 PM »
Each side of the dual driven axis must have its own home switch.  Each with their own input.  They cannot share an input.
Then Mach will home the slaved axis and square the axis as accurately as you have set up the switches.
Greg
« Reply #2 on: July 05, 2010, 08:53:52 AM »
I only have one switch for both the X-axis.
When "REF ALL HOME", only the Master X-motor is turning, the Slave X-motor is standing still.
Why??
« Reply #3 on: July 05, 2010, 08:56:50 AM »
On the Gen Config Page check the box that says "Home slave with master axis" A single home switch will be fine
