Hello
Guest
it is
November 22, 2026, 07:15:30 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Homing slave axis
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Homing slave axis (Read 10564 times)
Woodie K
2
Homing slave axis
on:
June 07, 2010, 08:07:27 PM »
I have a R&P driven with 2 steppers one on each end .
What is the best way to home both steppers to correct any misalignment at homing?
Logged
Greolt
956
Re: Homing slave axis
Reply #1 on:
June 07, 2010, 08:43:25 PM »
Each side of the dual driven axis must have its own home switch. Each with their own input. They cannot share an input.
Then Mach will home the slaved axis and square the axis as accurately as you have set up the switches.
Greg
Logged
Cois
2
Reply #2 on:
July 05, 2010, 08:53:52 AM »
I only have one switch for both the X-axis.
When "REF ALL HOME", only the Master X-motor is turning, the Slave X-motor is standing still.
Why??
Logged
BR549
6,965
Reply #3 on:
July 05, 2010, 08:56:50 AM »
On the Gen Config Page check the box that says "Home slave with master axis" A single home switch will be fine
Logged
Print
Pages:
1
Go Up
« previous
next »
