Hello Guest it is November 13, 2026, 05:55:46 PM
Author Topic: Plugin forced calls  (Read 7216 times)
Plugin forced calls
« on: May 29, 2010, 10:01:40 AM »
Don’t anyone know, is there a way to force a plugin to be run "called".  From what little I understand. Normally a plugin is called every 100mS.  I would like to be able to call a plugin from within a macro and have it run without delay!  Any ideas…
MiniDave ???
Re: Plugin forced calls
« Reply #1 on: May 30, 2010, 02:59:49 AM »
Yes, Use  the VB  "NotifyPlugins( some integer here)  then in your Plugin area in Machdeviceimplementation.cpp
in the notify code.
void   myNotify ( int ID)
   if( ID == myIntegerID ) //this is the integer you send from the VB NotifyPlugins(myIntegerID)
           do your code here;
scott
« Reply #2 on: May 31, 2010, 04:00:32 PM »
 ;D
Thanks Scott, Great help.
MiniDave
