Hello Guest it is October 30, 2026, 09:54:26 PM
Author Topic: have problem with latest version of mach  (Read 11881 times)
« on: May 26, 2010, 04:06:52 AM »
hi
i instaled latest version of mach and the problem begins what happen machine work and in random time mach3 will stop to work and i need to close the program and start again and then work ?
Are this happen only to me or ?
My Pc work on Windows 7 Pro and i use V Carve Pro for generatin gcode .
Please let me know what can be ?
Re: have problem with latest version of mach
« Reply #1 on: May 26, 2010, 04:10:43 AM »
i think you should change operating system to XP
amir
**Even a clock that does not work is right twice a day**
Offline mrpeja
  •  114 114
    • Embroidery Machines
« Reply #2 on: May 26, 2010, 08:24:55 AM »
Hi Goran,
 Speak serbian?
Yoy have on Machsupport somewhere instructions how to install Windows XP when you want to use Mach on this computer. I tink this is obvious!
Give up from Win7, XP is the right ting
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #3 on: May 26, 2010, 08:29:43 AM »
I use Mach 3 on Win7 almost every day, no problems at all. I do use a SmoothStepper and not the parallel port driver though. If you are using Win7 32bit I think the parallel port driver will work but you have to do the registry modifications, same as for Vista, which are detailed on the downloads page.
Happy machining , Jeff Birt
« Reply #4 on: May 26, 2010, 08:35:51 AM »
