Hello Guest it is November 23, 2026, 11:32:05 PM
Author Topic: Proximity Sensors Setup  (Read 12531 times)
« on: May 15, 2010, 11:49:27 PM »
Hi everybody.
I'm new to forum as well in Mach3.
I have just finished my CNC machine in which i have installed 4 proximity sensors, 2 for X, 1 for Y,Z axes.
What i can't figure out yet is how to set up my sensors in Mach3.
I have them all attached to pin 11 port 1.
All suggestions welcome.
Sergio.
Re: Proximity Sensors Setup
« Reply #1 on: May 16, 2010, 01:42:17 AM »
If you have them all connected to one pin then assign them all as that pin in Ports and Pins.
« Reply #2 on: May 16, 2010, 01:49:31 AM »
Thanks Hood
So you are saying that i should assign them to x++, x--, y++.....etc.
What about the X home, Y home...etc. Should i assign them there too ?
Sergio
« Reply #3 on: May 16, 2010, 01:51:19 AM »
Yes, as long as the switches are only seen by Mach when you activate them then that is what to do.
« Reply #4 on: May 16, 2010, 02:30:17 AM »
Thanks again Hood
