Hello Guest it is November 20, 2026, 10:07:25 AM
Author Topic: G code  (Read 41289 times)
Offline Tony Spencer
  •  8 8
  • Male Ipswich suffolk
G code
« on: May 12, 2010, 09:41:08 AM »
Hi All
Very new cnc and G code so need help. I am testing a new home built by machining a small mounting bracket for a stepper moter. The problem I have is with a pocketing operation in the centre of the bracket. The first pass is ok but the second is off centre in the y axis and  the third also off,and so on. The cumlative error produces a steped pocket at final depth. I am very new to CNC but is this problem related to g90 ,g90.1??
Any help would be appreciated
Re: G code
« Reply #1 on: May 12, 2010, 02:52:05 PM »
Can you post your code so we can check it?
  •  8 8
Re: G code
« Reply #2 on: May 12, 2010, 03:49:46 PM »
hi Jerry
Here is the code;
The profile cuts ok the problem is with the pocket
Code: [Select]
[( Made using CamBam - http://www.cambam.co.uk )
( stepperv3 5/12/2010 9:33:52 PM )
( T0 : 6.0 )
G21 G90 G64 G40
G0 Z1.5
( T0 : 6.0 )
T0 M6
( Profile1 )
G17
M3 S0
G0 X-50.0 Y-33.0
G1 F30.0 Z-1.0
G1 F300.0 X50.0
G3 X53.0 Y-30.0 I0.0 J3.0
G1 Y30.0
G3 X50.0 Y33.0 I-3.0 J0.0
G1 X-50.0
G3 X-53.0 Y30.0 I0.0 J-3.0
G1 Y-30.0
G3 X-50.0 Y-33.0 I3.0 J0.0
G1 F30.0 Z-2.0
G1 F300.0 X50.0
G1 Y30.0
G1 X-50.0
G1 Y-30.0
G1 F30.0 Z-3.0
G1 F300.0 X50.0
G1 Y30.0
G1 X-50.0
G1 Y-30.0
G1 F30.0 Z-4.0
G1 F300.0 X50.0
G1 Y30.0
G1 X-50.0
G1 Y-30.0
G1 F30.0 Z-5.0
G1 F300.0 X50.0
G1 Y30.0
G1 X-50.0
G1 Y-30.0
G1 F30.0 Z-6.0
G1 F300.0 X50.0
G1 Y30.0
G1 X-50.0
G1 Y-30.0
G1 F30.0 Z-7.0
G1 F300.0 X50.0
G1 Y30.0
G1 X-50.0
G1 Y-30.0
G1 F30.0 Z-8.0
G1 F300.0 X50.0
G1 Y30.0
G1 X-50.0
G1 Y-30.0
G1 F30.0 Z-9.0
G1 F300.0 X50.0
G1 Y30.0
G1 X-50.0
G1 Y-30.0
G1 F30.0 Z-10.0
G1 F300.0 X50.0
G1 Y30.0
G1 X-50.0
G1 Y-30.0
( Pocket1 )
S0
G0 Z1.5
G0 X1.6 Y0.0
G1 F30.0 Z-1.0
G2 F300.0 X-0.8 Y-1.3856 I-1.6 J0.0
G2 Y1.3856 I0.8 J1.3856
G2 X1.6 Y0.0 I0.8 J-1.3856
G1 F30.0 X4.0
G2 F300.0 X-2.0 Y-3.4641 I-4.0 J0.0
G2 Y3.4641 I2.0 J3.4641
G2 X4.0 Y0.0 I2.0 J-3.4641
G1 F30.0 X6.4
G2 F300.0 X-3.2 Y-5.5426 I-6.4 J0.0
G2 Y5.5426 I3.2 J5.5426
G2 X6.4 Y0.0 I3.2 J-5.5426
G1 F30.0 X8.8
G2 F300.0 X-4.4 Y-7.621 I-8.8 J0.0
G2 Y7.621 I4.4 J7.621
G2 X8.8 Y0.0 I4.4 J-7.621
G1 F30.0 X11.2
G2 F300.0 X-5.6 Y-9.6995 I-11.2 J0.0
G2 Y9.6995 I5.6 J9.6995
G2 X11.2 Y0.0 I5.6 J-9.6995
G1 F30.0 X13.6
G2 F300.0 X-6.8 Y-11.7779 I-13.6 J0.0
G2 Y11.7779 I6.8 J11.7779
G2 X13.6 Y0.0 I6.8 J-11.7779
G1 F30.0 X16.0
G2 F300.0 X-8.0 Y-13.8564 I-16.0 J0.0
G2 Y13.8564 I8.0 J13.8564
G2 X16.0 Y0.0 I8.0 J-13.8564
G0 Z1.5
G0 X1.6
G1 F30.0 Z-2.0
G1 F30.0 X4.0
G1 F30.0 X6.4
G1 F30.0 X8.8
G1 F30.0 X11.2
G1 F30.0 X13.6
G1 F30.0 X16.0
G0 Z1.5
G0 X1.6
G1 F30.0 Z-3.0
G1 F30.0 X4.0
G1 F30.0 X6.4
G1 F30.0 X8.8
G1 F30.0 X11.2
G1 F30.0 X13.6
G1 F30.0 X16.0
G0 Z1.5
G0 X1.6
G1 F30.0 Z-4.0
G1 F30.0 X4.0
G1 F30.0 X6.4
G1 F30.0 X8.8
G1 F30.0 X11.2
G1 F30.0 X13.6
G1 F30.0 X16.0
G0 Z1.5
G0 X1.6
G1 F30.0 Z-5.0
G1 F30.0 X4.0
G1 F30.0 X6.4
G1 F30.0 X8.8
G1 F30.0 X11.2
G1 F30.0 X13.6
G1 F30.0 X16.0
( Drill1 )
S0
G0 Z1.5
G0 X-23.5 Y23.5
G81 Z-10.0 R1.5 F30.0
G81 X-40.0 Y0.0 Z-10.0
G81 X-23.5 Y-23.5 Z-10.0
G81 X0.0 Y0.0 Z-10.0
G81 X23.5 Y23.5 Z-10.0
G81 X40.0 Y0.0 Z-10.0
G81 X23.5 Y-23.5 Z-10.0
G80
M5
M30
/code]
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: G code
« Reply #3 on: May 13, 2010, 06:05:20 AM »
I had a quick look at your code and it looks fine, I think you may be loosing steps in the Y axis.
Graham
  •  8 8
Re: G code
« Reply #4 on: May 13, 2010, 07:13:28 AM »
I checked the y axis by running a loop that returned y to o over 50cycles and it was fine! I don't think I am loosing steps. If i cut a rectangular pocket on x ,y its fine no problem but if i slew the pocket by say 10 deg i have the same problem with a stepped pocket as i did with the circle pocket in the original g code.
Thanks for your help.
Tony
Re: G code
« Reply #5 on: August 15, 2010, 06:13:45 AM »
Graham,
I've built a cnc quilting machine, that uses Mach3 to control it.  I need a way to reset the dro's to zero at the end of a pattern, and then restart at the same place, thereby extending/repeating the pattern, connected end to end.  Any ideas?
Larry
  •  2,785 2,785
Re: G code
« Reply #6 on: August 15, 2010, 06:20:02 AM »
Use a G52 X? Y? to shift the datum the pitch of the pattern at the end of the run put a G52 X0 Y0 in the program
Put the pattern code in a sub program and just call it with a M98 Pnnnn
Graham
Re: G code
« Reply #7 on: August 15, 2010, 07:57:33 AM »
Graham,
I'll give that a try and see what happens.  I'll let you know what happens.
Larry
  •  2,785 2,785
Re: G code
« Reply #8 on: August 15, 2010, 08:00:20 AM »
If you need some help with the format of the code just send me a PM.
Graham
Re: G code
« Reply #9 on: August 15, 2010, 10:40:03 AM »
Graham,
I tried the code that you recommended and unfortunately no joy.  The code would work if it were a milling machine, however, since it isn't, the quilter only recycles to the front of the pattern and starts over at the datum.  I have been fighting this issue for about 6 months now, and I know that there is a way to do it, I just can't find it.
Larry
