Hello
Guest
it is
November 20, 2026, 10:07:27 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
G code
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: G code (Read 41290 times)
Graham Waterworth
2,785
Yorkshire Dales, England
Re: G code
Reply #20 on:
September 23, 2010, 12:00:51 PM »
Sorry Larry, my fault, the macro code should read :-
Setvar(3, getuserdro(1001))
You had the M code in the right place.
I must have been having a bad day.
Graham
Logged
LarryL
61
Re: G code
Reply #21 on:
September 23, 2010, 12:10:26 PM »
Ok thanks Graham, just recall that King Henry had a worse day!
Larry
Logged
LarryL
61
Re: G code
Reply #22 on:
September 23, 2010, 12:35:13 PM »
Graham,
Well, I guess I'm the one having a bad day. There must be something that I am doing wrong. I put the M at the #3 place, and I have a DRO on the screen with the 1001 in the OEM Code function window.
Larry
Logged
Graham Waterworth
2,785
Re: G code
Reply #23 on:
September 23, 2010, 12:39:10 PM »
Have you got the macro saved in the correct profile?
If you are using the standard mach3mill profile it needs to be stored in C:\Mach3\macros\Mach3Mill as M1001.m1s
Graham
Logged
LarryL
61
Re: G code
Reply #24 on:
September 23, 2010, 12:48:36 PM »
Graham,
Dude you nailed it. I had to put it in the subfolder called cnc_quilter, then it started working perfectly, you are truly the man. Go have pint on me!
Larry
Logged
Graham Waterworth
2,785
Re: G code
Reply #25 on:
September 23, 2010, 12:51:06 PM »
Send only huge bags of cash
You are welcome
Graham
Logged
LarryL
61
Re: G code
Reply #26 on:
October 30, 2010, 12:26:19 PM »
Graham, my friend, I need to draw on your limitless knowledge fount! Is there a way to constantly provide the updated position of an axis so that it can be acted upon by an if then operation?
Larry
Logged
Graham Waterworth
2,785
Re: G code
Reply #27 on:
November 01, 2010, 05:13:49 AM »
No, as there is no way to flush the current move from the buffer and do a restart from the current position.
Graham
Logged
LarryL
61
Re: G code
Reply #28 on:
November 01, 2010, 08:06:13 AM »
Graham,
I thank you my friend, now back to the grind!
Cheers,
Larry
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
