Hello Guest it is September 18, 2026, 01:14:33 PM
Author Topic: problem by Torch ON and OFF  (Read 7774 times)
« on: May 10, 2010, 01:23:13 AM »
 hi all
i use mach3 with THC(In addition Sheetcam) for plasma machine.
when i run code(by CycleStart),Z Moves down to trig switch float, and Z=0 and code start, Consider We cut form a Square. now run code.Quarter cut will, and we press key STOP, here X & Y & Z is stop and TORCH IS OFF, now we again press cycle start ,my problem is : code Continues BUT TORCH NOT ACTIVE.
Please guide how the torch is automatically turned When Again the cycle button is pressed.
**Even a clock that does not work is right twice a day**
