Hello Guest it is November 23, 2026, 03:14:31 PM
Author Topic: LPTx in PC vs Port#1 in Mach3 ??? just need to clarify  (Read 13044 times)
« on: May 03, 2010, 03:52:58 PM »
My computer has no parallel port on motherboard, so I bought a PCI parallel port board, and I set it as LPT2 in PC. While in Mach3, I clicked the port#1 and input the related LPT2 address. It works, anyway.
Does it really matter if I set PCI as LPT1 or LPT3 or LPTx as long as I set port#1 with correct address?
I tested with setting as LPT1 in PC, it works too. why?
Thanks.
Re: LPTx in PC vs Port#1 in Mach3 ??? just need to clarify
« Reply #1 on: May 03, 2010, 04:59:40 PM »
As you have found the Port in Mach has no relation to the LPT number that windows calls it, Mach just looks at the address you enter.
« Reply #2 on: May 04, 2010, 08:53:27 PM »
So how do you find out the port address of your Port ??
« Reply #3 on: May 05, 2010, 01:18:56 AM »
Look at the resources of the port in Device Manager.
