Hello Guest it is October 23, 2026, 04:26:40 AM
Author Topic: Homing Trouble KX1  (Read 33534 times)
Re: Homing Trouble KX1
« Reply #10 on: April 30, 2010, 05:12:12 PM »
If I reverese the homing direction the the other switch on X will work.
Here is the file. THANKS FOR YOUR HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
« Reply #11 on: April 30, 2010, 05:16:23 PM »
That would to me suggest a bad switch then. Why you see it showing on diagnostics page I do not know. Will look at your xml and see if I can find a problem.
« Reply #12 on: April 30, 2010, 05:20:53 PM »
I'll try to explain this. If I home posiitive and push the switch that the machine would hit in the negative direction it will work and vis versa. Seems like I need to reverse the switches? I'm I making any since?
« Reply #13 on: April 30, 2010, 05:23:53 PM »
xml looks fine and seems to be working fine here in simulation.
Dont understand how reversing the homing direction would affect things as you have your switches wired in series so Mach doesnt know which switch is being seen.
« Reply #14 on: April 30, 2010, 05:30:56 PM »
That is what I was thinking. Any Ideas?
« Reply #15 on: April 30, 2010, 05:35:41 PM »
Afraid not, only thing I can suggest is download Mach again and install over the top of itself.
Worst comes to the worst you could home the opposite way and just set a Home Off value.
« Reply #16 on: April 30, 2010, 05:37:31 PM »
GOT IT... I reversed the wires on the curcit board labeled X+ and X- that are wired to the limit switches and we have lift off. Thanks for the help.
« Reply #17 on: May 01, 2010, 04:45:49 AM »
Not really sure I follow as you have al X wired in series  so no matter which wire is  which it should not matter, they are only acting as a closed circuit when non activated and an open circuit when activated.
Main thing, I suppose,  is you now  have things working.
« Reply #18 on: May 02, 2010, 12:29:47 AM »
Hi all!
When our cnc machine automatically traveling to home position(after end of gcode work ),the x & Y axis is properly stop at 0,0 position but the z axes hits the work table at (-50) position(for example). Please Help me!
mostafa
« Reply #19 on: May 02, 2010, 01:41:50 AM »
Sounds like you are losing steps, try detuning your Z axis a bit, also check the axis for any roughness or binding.
