Hello Guest it is November 22, 2026, 09:15:08 PM
Author Topic: Homing Trouble KX1  (Read 34405 times)
Re: Homing Trouble KX1
« Reply #20 on: May 02, 2010, 04:05:32 AM »
Dera Hood,
Thanks for your reply,
I don't understand losing steps in z axes!please guide me further If possible.
Why does  when machine is duration of work we don't have any losing step!!?
And I think we don't have any roughness or binding.
I'll wait for your early reply.
« Reply #21 on: May 02, 2010, 05:25:42 AM »
Ok maybe I misunderstood your question, can you try and explain a bit clearer what is happening.
Does the Z DRO in Mach show the position the tool is at or does the DRO show where the tool should be?
« Reply #22 on: May 02, 2010, 01:26:43 PM »
Ok , I've to explain you again:
Our machine was worked for long time with any problem.
But 3 days a go this problem was happened:
When the cnc machine complete the hacking work, automatically traveling to home (the gcode line number is final line & the gcode traveling position is x=0/y=0/z=0).
Hence, x & y axes travleing to "0" position but z axes crossing the "0" position and hits the table.for example the position of z at this time is "-50" but It should be "0" position.
And finally the counter display of mach3 showing{ x = 0,y = 0,z = -50}!!
« Reply #23 on: May 02, 2010, 03:52:55 PM »
Please attach your code and your xml and also the fixtures.dat and tools3.dat, you will find the last two in the macro folder of the profile you are using.
« Last Edit: May 02, 2010, 03:56:54 PM by Hood »
