Hello Guest it is October 21, 2026, 03:13:05 AM
Author Topic: Fanuc MPG Voltage  (Read 21388 times)
Fanuc MPG Voltage
« on: April 29, 2010, 08:40:05 AM »
I've got a shot at several Fanuc MPG's pretty cheap.
I am asking if any of you folks know if Fanucs are typically 5V.......or ?
Re: Fanuc MPG Voltage
« Reply #1 on: April 29, 2010, 09:28:05 AM »
Fanuc are principally 5vTTL , some models are single ended, A & B,  some have differential, both can be used in the single ended mode.
There are some Mits/Mazak out there that are 12vdc supply with 5v signal.
Nosmo.
« Reply #2 on: April 29, 2010, 01:31:29 PM »
BTW, they are standard 100 p/rev.
N.
« Reply #3 on: April 29, 2010, 02:20:42 PM »
Thanks Nosmo,
  Might just pick them up then.
Russ
« Reply #4 on: May 16, 2011, 09:43:20 AM »
I picked up a Fanuc MPG the other day. very cool. runs off 5V and has 2 outputs produces 4.2V square waves 180 deg apart. I found this page that details it.
« Reply #5 on: May 16, 2011, 09:43:53 AM »
Now I just need to figure out how to interface it to Mach?
« Reply #6 on: May 16, 2011, 10:08:05 AM »
The standard is 90° apart, Hence quadrature pulses. The PDF confirms this.
N.
« Reply #7 on: May 16, 2011, 10:10:00 AM »
Oh yeah duh yea yea 90deg apart ooops.
