Hello Guest it is November 10, 2026, 01:52:33 AM
Author Topic: P, Q, R parameter  (Read 38958 times)
Offline flick
  •  15 15
P, Q, R parameter
« on: April 22, 2010, 09:16:45 AM »
The value passed to Q seems to "cascade" down to R, and then persists if R is not specified in successive calls.  Feature? Known issue? Already fixed?
Offline flick
  •  15 15
Re: P, Q, R parameter
« Reply #1 on: April 22, 2010, 06:02:03 PM »
I was playing around a little more with this today, and the cascading effect I thought I had seen yesterday is gone.  The more I think about it, the more I think that I made it up by happenstance.  Plus I was really tired.  But the persistence is still there.
Whereas Param1() and Param2() always return -1 if P and Q, respectively, are left out of the macro call,  Param3() will return whatever value was last used with R.  It's even persistant between different macros.
« Reply #2 on: April 26, 2010, 09:16:46 PM »
I can confirm that. It seems to be a bug.
Test
'm1009 test macro
Message "" &param1 &param2 &param3
end
create macro then add params to the macro call. The values will show up in the mach message line. Then call the macro without params and it displays
-1,-1, what ever number that was in R.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #3 on: April 27, 2010, 04:30:19 AM »
I'd suspect that this is tied up with cypress enable's appaling stack handling which is and allways has been broken.
Offline flick
  •  15 15
« Reply #4 on: April 27, 2010, 11:31:25 AM »
Is that also why we can't nest macro calls?  It sure is tough to develop a general purpose macro library without nesting...
Offline stirling
  •  2,188 2,188
  • UK
« Reply #5 on: May 01, 2010, 11:14:41 AM »
What happens?
« Reply #6 on: May 02, 2010, 10:46:41 AM »
HIYA Stirling, question ,there is a fellow doing probing of an engine intake ports. Can your crawler routine probe the inside of a 3d object such as a port?
Offline stirling
  •  2,188 2,188
  • UK
« Reply #7 on: May 02, 2010, 12:50:08 PM »
Hi - It's basically a bed o' nails with the added benefit of only probing inside a prescribed boundary. As you know a standard or dumb bed o nails only probes inside a defined rectangle which can mean it spends an inordinate amount of time probing useless space. All I can sugest is your fellow gives it a whirl. Don't know if you've seen it but there's an Italian company in this thread www.machsupport.com/forum/index.php/topic,4352.msg97649.html#msg97649 that has a couple of nice vids on their site and youtube of the routines in action.
Let me know how you get on.
Ian
« Reply #8 on: May 02, 2010, 12:58:04 PM »
HUM there is really nothing to probe in the Z axis just a big hole. The area to probe would be in the X/Y directions and step down in z as it goes deeper into the port.
Your crawler routine works great but I don't think it will work in this application unless it could be modified to crawl the perimeter from the inside out then step down.
(;-) There IS a market for a PORT probing routine to do this IF you are interested.
I have seen your routine do the combustion chambers of the head, that IS a perimeter and bed of nails type of probing solution
Thansk
« Last Edit: May 02, 2010, 01:02:30 PM by BR549 »
Offline flick
  •  15 15
« Reply #9 on: May 02, 2010, 10:16:56 PM »
What happens?
Hrm, can't find it anymore, thought I'd read it wasn't allowed. Brain fart?
