Hello Guest it is November 10, 2026, 01:54:46 AM
Author Topic: P, Q, R parameter  (Read 38959 times)
Offline flick
  •  15 15
Re: P, Q, R parameter
« Reply #20 on: May 03, 2010, 06:53:24 PM »
Note: V4 is suppose to have that fixed(nestingmacros)
There's a V4?  I'm stuck with Tormach's current release, need a workaround.
« Reply #21 on: May 03, 2010, 09:22:58 PM »
Then try the semaphore approach it does seem to work.  Do a search on this forum for semaphore Ray gives and example of how he did it.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #22 on: May 04, 2010, 03:54:21 AM »
If you don't actually want or need the parallel behaviour of the multiple macros, it seems a bit overkill to start messing with home rolled semaphores just to get a "sub call". Why not just put your library routines in... erm... a library i.e. a DLL?
Ian
