Hello Guest it is October 21, 2026, 04:04:54 AM
Author Topic: mach cant remember z axis reading  (Read 10070 times)
« on: April 18, 2010, 11:21:50 AM »
I am new to the board and mach3. I am using the ajax plugin to control my motion controler. My question is when I turn my controler on all the dro remembers what positions I was in except for the z axis. I know the encoder is working because I can turn the motor shaft and the dro works. I just loose my reading if I reboot. Thanks for any input. Scott
Re: mach cant remember z axis reading
« Reply #1 on: April 18, 2010, 11:35:31 AM »
Do you have "persistent dros" in the axis section of general config?
« Reply #2 on: April 18, 2010, 04:52:22 PM »
Not many people using the Ajax/Mach combo yet and its probably an issue with the Ajax plugin so likely your best option would be to ask them. If you get a solution from Ajax please post back with the answer as it will help others in the future as I am sure it will become a more popular option.
