Hello Guest it is October 24, 2026, 08:53:19 PM
Author Topic: A-axis not working right after Mach upgrade  (Read 7746 times)
« on: April 15, 2010, 04:05:34 PM »
  I tried to update Mach to the latest lock down version. I was using 3.041 and the current Smooth Stepper plugin, everything was working fine. After the update I can jog all of the axis's no problem but when I try to run a program, that ran fine in the old version, will not run right in the new one.  Now whenever the z-axis is moving at the same time as the a-axis is rotating everything goes to a crawl. but the z retract and the x move back are fine. I tried changing every setting that I could think of but nothing works. If I run a program that only uses the x,y, and z axis's it works fine. Does anyone have any idea on what is going on?  For now I will just go back to the old version.
Tom
