Hello Guest it is November 22, 2026, 01:49:49 PM
Author Topic: Help with activating m3, m4, m5 when condition is met  (Read 9349 times)
« on: April 12, 2010, 11:37:55 PM »
Hello, what is the easiest way to do the following. I can't seem to get it to work.
Activate spindle relay Clockwiise - M3
Stop sprindle (M5) when freedrate DRO > 19 (feedrate DRO  is 821)
If input 1 (port 0, pin 6) is active then Activate spindle CCW - M4
Stop sprindle (M5) when freedrate DRO < 2
Any help would greatly be appreciated!
« Last Edit: April 12, 2010, 11:39:39 PM by omegasea21 »
Re: Help with activating m3, m4, m5 when condition is met
« Reply #1 on: April 13, 2010, 01:31:41 AM »
Easiest way is to write a macropump to do what you want. I am not the best at VB but something like this should work
Spindle = GetOemDRO(821)
If Spindle >19 Then
Code("M5")
If IsActive(InPut1) Then
Code("M4")
If Spindle <2 Then
Code("M5")
End If
End If
End If
« Reply #2 on: April 13, 2010, 09:29:09 PM »
Thank you so much!!!
