Hello
Guest
it is
November 24, 2026, 04:22:20 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
new user - No signal to board - I think?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: new user - No signal to board - I think? (Read 12471 times)
Mike.Stott
on:
October 07, 2006, 10:29:47 AM »
Hello
I have down loaded Mach3 1.84 and have it running on a desk top 2.6 processor. I can get it to work (simulate) by pushing the "off line" button then the RESIT button stops blinking. I can run programs and the axis record movement.
When I do not have it on "off line" I can not get it to RESIT it just keeps blinking. I think my problem is that it is not getting a signal from the computer to my control board. My control board is HobbyCNC's newest 4 axis pro board. The board does work with my Deskcnc program but I would like to upgrade to MACH3. I'm using the free down load of Mach3 at this point to see if I can get it to work before I buy the open version.
Again It seems that I'm not getting a signal to the board or that the program can not find the board.
Any help would be welcome.
Mike
Re: new user - No signal to board - I think?
Reply #1 on:
October 07, 2006, 10:34:13 AM »
If you go to config menu then ports and pins you will see the Input Signal tab, scroll down until you see E-Stop and change the active state. That should allow you to reset.
Reply #2 on:
October 07, 2006, 10:37:38 AM »
BTW have a look at the setup video on the downloads page, it will give you an idea of how to configure your ports and pins for each axis, limits etc.
Mike.Stott
Reply #3 on:
October 07, 2006, 10:53:12 AM »
Thank you Hood
I went out and tried to uncheck the estop but after clicking apply and then ok I tried the reset button and it would not reset. So I went back and checked my estop setting and it was checked with a green check so I unchecked it again now showing a red x click apply and ok again then clicked the rest and it would still not reset. So I opened it again and it had changed itself bach to a green check. So I unchecked it again still the same thing happened.
Any thoughts?
I see that you suggested I look at the vidio and I will do that thanks again.
Mike
Reply #4 on:
October 07, 2006, 10:55:03 AM »
Yes
Its the the state (Active low) you have to change, the E Stop cant be disabled as you have found.
Print
Pages:
1
Go Up
« previous
next »
