Hello Guest it is November 19, 2026, 04:08:37 PM
Author Topic: PROBLEMS with G00 and G01.  (Read 8558 times)
« on: April 02, 2010, 09:50:22 PM »
I am running a GCODE, for operate  wheel of sewing machine in an embroider project.
In this moment Iam using Z axis for this movement,  until I change for A axis.
My set up of Z axis is in this way
Steps x Revolution = 800 (200- ΒΌ microstep)
Mm x revolution = 10 (simulated)
Steps x MM = 80.
Vel    3000 mm/min
Accel = 500 mm/sec/sec
I created  two variants of CGODE Lines
For two variants F = 3000
1-G00 Z10----------In this case 100 first lines runs in 59 secs
2- G01 Z10---------In this case 100  first lines runs in 45 secs.
I think that  GCODE with G00 in Z movements should be more faster than second variant.
What do you think about that?
Thanks in advance, sorry my bad English.
Regards
Rene
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: PROBLEMS with G00 and G01.
« Reply #1 on: April 03, 2010, 02:01:57 PM »
Not always the case,  when you run a G00 command there is no CV blending so the movement is stopped after every move command.
Graham
