Hello Guest it is November 13, 2026, 11:57:59 AM
Author Topic: Turn Eccentric Wizard  (Read 47964 times)
Re: Turn Eccentric Wizard
« Reply #10 on: March 29, 2010, 01:50:21 PM »
Sounds like its back to 4 jaw chucks and dial gauges then.
Thanks for the inputs.
Clive
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #11 on: March 31, 2010, 07:41:44 AM »
You would need a lathe with a Y axis for a start so you could maintain the tool centre height.
Graham
« Reply #12 on: March 31, 2010, 07:54:51 AM »
Excellent point there Graham, I completely overlooked that aspect.
« Reply #13 on: March 31, 2010, 11:13:16 AM »
Very Good point I will definately stick to 4 jaw chuck
Clive
« Reply #14 on: March 31, 2010, 12:35:09 PM »
Looks like nobody watched the video posted by wantcnc ???
Phil
« Reply #15 on: March 31, 2010, 12:46:29 PM »
I did Phil. It is so very impressive! I have no idea what it takes to make the gcode for this part... ??? Are there CAM packages that can handle such things?
Daniel
« Reply #16 on: March 31, 2010, 01:46:19 PM »
I did too.
« Reply #17 on: March 31, 2010, 01:52:55 PM »
Looks to me like the Mazak has a Y axis unless its just an optical illusion.
  •  2,785 2,785
« Reply #18 on: March 31, 2010, 02:15:45 PM »
Clive,
if its a repeat job bore a offset hole in a round billet and split it through the thick side then you can hold it in the three jaw.
Graham
« Reply #19 on: March 31, 2010, 02:26:26 PM »
Thats a very good idea Graham, but I was only being lazy.
I seem to speed ages setting up 4 jaw chucks
Clive
