Hello Guest it is November 23, 2026, 01:07:58 PM
Author Topic: Turn Eccentric Wizard  (Read 48186 times)
Re: Turn Eccentric Wizard
« Reply #20 on: March 31, 2010, 02:31:08 PM »
Having thought about it for a bit, that ony gives you an offset arc not an eccentric circle!!
« Reply #21 on: March 31, 2010, 03:01:40 PM »
Looks to me like the Mazak has a Y axis unless its just an optical illusion.
It certainly has a Y axis, doesn't look like an illusion because the tool remains in contact (centre line) of the work. Any ideas how the gcode was made?
Daniel
« Reply #22 on: March 31, 2010, 03:34:44 PM »
Daniel
Guy says he wrote a home made macro.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #23 on: March 31, 2010, 05:16:06 PM »
The code is the easy bit the hard bit is getting a machine that can follow the code instructions,  you need the X or Y axis to be in sync with the spindle.  Then the code is generated using Sin and Cos of a selected arc length on a offset centre point, the Z movement is then divided into the number of cords.
If you make the conforming machine I will write you the code.
Graham
« Last Edit: March 31, 2010, 05:18:06 PM by Graham Waterworth »
« Reply #24 on: April 01, 2010, 12:57:09 AM »
Don't they both need to be in sync... but then from the nature of how Mach works, if you get one in sync, the other would be automatically in sync.
If I see right, the part cut in the video is a square. I think using the method you suggest would cut a circle...?
Ha..ha... thanks Graham. As you say it's the machine that is the hardest part, but I will remember your offer if I ever build/buy one ;)
Daniel
« Reply #25 on: April 01, 2010, 02:06:32 AM »
I'm not sure yuo do need an Y axis, in that video the indeed use it, however in this video it is not used
http://www.youtube.com/watch?v=gX75gaAcWWA&feature=related
also it mentiones gibscam as the cam generator...
Still the machine axis sync seems to me the hardest thing to solve, stepper drive will be so slow that cutting speeds will be to low
, unless you have fitted servos
I do like the of center clamp insert though...
  •  2,785 2,785
« Reply #26 on: April 01, 2010, 02:59:20 AM »
This is why you need a Y axis
Graham
  •  2,785 2,785
« Reply #27 on: April 01, 2010, 03:10:52 AM »
Daniel,
If I was cutting a square on and eccentric peg then I would use the chuck as a rotary indexer and mill the flats, why make life hard  :D
But the square code is doable too.
Graham
« Reply #28 on: April 01, 2010, 07:25:50 AM »
Agree with you, Graham.
Just curious how would look the code for a square? Looks like it's Sin and Cos minus some product of them with some relative parameter...?
Daniel
